Skorpion kick stand tab broke.......now what ?
Postby hb7 » Thu Nov 26, 2015 2:20 pm
This is not a simple thing to repair, when you think about how much the weight/stress and the geometry.
Apparently they used cheese quality steel for the kickstand. The hole has elongated and the metal fractured.
Thinking I could stick weld and grind down...new material.
or cut and weld a new tab...(more uncertainty and more fabrication work)
Submit all ideas....to fix it once and for all.
I'm never letting go. They have to pry my MZ Skorpion from my cold dead hands....
New kickstand tab : http://www.thefactorymetalworks.com/Weld_On_Kick_Stand_Tab_for_triumph_bsa_custom_p/fmw-kicktab.htm
hb7
Re: Skorpion kick stand tab broke.......now what ?
Postby tigcraft » Fri Nov 27, 2015 5:14 pm
Good job you've a centre stand!! Well I'd reshape that round the pin that went through it. Couple of tacks either end then massive V grind down the middle and weld the slot just created. For good measure I'd possibly also weld a washer on the back too with similar profile.
tigcraft
Postby hb7 » Fri Nov 27, 2015 5:48 pm
that Kickstasnd bushing is hardened.....the metal tab is not.
no room for a washer on the back side.
washers are soft too....
maybe run a few beads on the front and grind them down for a tighter kickstand yoke fit
hb7
Users browsing this forum: Google [Bot] and 18 guests
