A Baghira Master Cylinder on Amazon
Postby cmg241 » Sun May 01, 2016 12:45 pm
Looks like I joined the club of failed Grimeca master cylinders though found a cheap solution.
http://www.amazon.com/Hanpearl-Universa ... ge_o04_s00
The bars are 22cm which was the easy part, I was concerned about the banjo bolt size. Any way the one it came with fit perfectly, not pretending it's high quality but it fit. $38 US and it even came with a brake lever. lever is a little too long to fit in the Acerbis hand guard but I will figure it out.. I am having a little issue with pressure but could just be air in line. I posted a question on Amazon and a couple guys with bigger/heavier bikes said works fine for them.
cmg241
Re: A Baghira Master Cylinder on Amazon
Postby mincehead » Mon May 02, 2016 5:25 am
Never had a problem with mine, junked the Grimeca caliper for a goldline Brembo though. :wink:
mincehead
Postby cmg241 » Mon May 02, 2016 5:46 am
Hmm do you have a part number for that Brembo caliper? Thanks, Chris
cmg241
Users browsing this forum: Bing [Bot] and 20 guests
