New member, UK
New member, UK
Postby ivor » Tue Mar 07, 2017 5:30 am
Hi all, I'm Tony from Surrey in the UK. I use the monicker 'Ivor' on a number of forums, it was a nickname I gained some years ago, and I often use it online.
I have quite a few bikes, and I am the motorcycle team at Brooklands museum. I don't have any prejudice against any kind of bike or where they originate, but my preference is for old Brit stuff. Particularly for pre-War and older.
I'm currently renovating an MZ 125/150 (started life as a 125, but fitted with 150 top end). It's not mine, but a friend's. I have nearly finished, but just have a few niggling things to fix. I'll post later in the vintage section and tell you where I'm at.
Cheers, Tony (or ivor !).
ivor
Re: New member, UK
Postby den » Wed Mar 08, 2017 1:00 pm
hi tony , welcome bro
den
Re: New member, UK
Postby therealche » Thu Mar 09, 2017 6:05 pm
Hi Ivor. Well now you see what a well put together bike it is,I'm sure you will be getting one yourself!
therealche
Re: New member, UK
Postby Blurredman » Fri Mar 10, 2017 4:06 am
Hello!
Welcome!!
Re: New member, UK
Postby ivor » Mon Mar 13, 2017 6:55 am
therealche wrote:Hi Ivor. Well now you see what a well put together bike it is,I'm sure you will be getting one yourself!
I had a TS150 in the early Eighties. It was a great bike, though I did end up seizing the bottom end solid !
ivor
Re: New member, UK
Postby ivor » Mon Mar 13, 2017 6:56 am
Still had no reply to my technical question. Any of you guys know what I do regarding the two wires that go to the same bulb ?
ivor
