Water pump wanted.
Water pump wanted.
Postby chief » Fri Apr 07, 2017 3:14 pm
I have a 94 Skorpion 660. In need a a water pump. Living in the usa. Any suggestions would be appreciated.
chief
Re: Water pump wanted.
Postby edfmaniac » Fri Apr 07, 2017 9:16 pm
This might help you out on a budget. I believe it's the same pump. What's the problem with yours?
http://www.off-the-road.de/en/XT-660Z/W ... T-660.html
Postby chief » Sat Apr 08, 2017 1:30 pm
I cant get pump to stop leaking out the vent. Using a Raptor 660 pump repair kit. ??
chief
Postby edfmaniac » Sat Apr 08, 2017 8:19 pm
Sounds logical but I don't know for sure if there are any differences in the water pump area. Can you compare the Raptor 660 rebuild kit to the one in the link I provided? If they look the same, you are probably headed in the right direction. The site in the link also sells a great kit for the carb on our bikes. It improves throttle response and overall flow through the CV carb. But don't use their jetting recommendations.
Postby chief » Sun Apr 09, 2017 8:08 am
The kit's do look identical. I have another kit on the way.
chief
Postby chief » Sun Apr 09, 2017 8:13 am
chief
Postby DAVID THOMPSON » Sun Apr 09, 2017 12:37 pm
yamaha part numbers tell a story
5LP-12420-00-00 is a water pump
4SU124200000 is a szr 660 pump note the first 3 letters
very good chance its the same pump
do a search for Yamaha water pump 12420
and see how many you get back
this may not always work
but it does very often
but caution 3yf at the start is the impeller not the pump
and some sites list what it fits
Postby chief » Wed Apr 12, 2017 8:01 pm
The raptor pump which looks identical. The clocking is just off by about 2mm. That cost me 35 bucks. I will keep looking. Trying to find SZR pump ? Thanks for imput.
chief
Postby DAVID THOMPSON » Wed Apr 12, 2017 9:42 pm
what do you mean by the The clocking is off
i learned in the basement with dad and he did not use too many words just show
Postby chief » Thu Apr 13, 2017 8:43 pm
All the bolt holes on housing to case line up except one is off by about 2mm.
chief
Postby DAVID THOMPSON » Thu Apr 13, 2017 9:51 pm
try rotating it and see if there is any where it lines up
and the pump fits
may be something in the case that required them to make one a bit off instead of equal spacing
so they could drill the hole and not have the bolt cause a problem
or on purpose to keep some one from putting the pump in the wrong engine
Postby edfmaniac » Fri Apr 14, 2017 3:58 am
I found multiple OEM Yamaha parts on Ebay UK that show they fit the water pumps on both the XTZ660 and the SZR660. I'm pretty sure that kit I posted in the link will work. Maybe contact them and ask about MZ compatibility?
Edit: Just discovered that the XT660-Z and the XTZ660 are two different bikes. Sorry! I'd still contact them to see if it fits. Yamaha engines borrow lots of parts from one another.
Postby chief » Sat Apr 15, 2017 6:55 am
My friends I picked up an OEM Yamaha water pump kit and pump is now working and not leaking. The only difference I could see with the kit is that the rubber gasket that houses the porcelain washer that sits in the impeller is of better quality. Again thanks for imput. I would like to know if the SZR pump would fit the MZ ?
chief
Users browsing this forum: Bing [Bot] and 19 guests
