Mastiff carbs removal
Postby breakwellmz » Tue Feb 06, 2018 11:06 am
Any hints or tips on removal of the carbs from my Mastiff?
So far-tank off, all three cables, any visible tubes, air filter.Any fastenings have have a spray of penetrating oil to soak in overnight.
I assume they come off in one lump?
Re: Mastiff carbs removal
Postby DAVID THOMPSON » Tue Feb 06, 2018 6:13 pm
if its similar to my traveller its not easy
do take lots of pictures and do not break stuff
a box to put small stuff in lost parts are hard to find
Postby breakwellmz » Thu Feb 08, 2018 10:37 am
Hi
Thanks for that David.
It turned out not as difficult as i imagined, although not helped by working outside in the cold!
What did help was my lightbulb moment in deciding to unbolt the upper subframe location bolt.That meant the intake rubbers pulled away from the back of the carbs and gave me a bit more maneuvering room.
I took it out from the LH side.
Cheers
