TS250/1 Sluggish return to Idle
Postby Daniel_I » Thu May 03, 2018 9:20 pm
Hi All,
After revving up, it seems to take a little longer to return to Idling revs (~1600rpm) than I would like. Is this normal for this model of M/C ? or is there something not quite correct?
Daniel_I
Re: TS250/1 Sluggish return to Idle
Postby Puffs » Fri May 04, 2018 3:06 am
Hi Daniel!
Suggest to check your throttle cable for strands that are broken off, and routing without kinks. If it's clean, then lube it with a thin oil; work some oil into the cable. When you open the throttle & then let go, the carb should say 'cloink' when the slide hits the stop. The grip should also move freely, and can also be lubricated. If all is mechanically OK, it might run a bit lean.
On your clutch issue, I don't know your specific bike, but yes, I have noticed that an ETZ251 clutch that's not been used for a while can stick a bit, and that goes away with use.
Postby Blurredman » Fri May 04, 2018 4:26 am
Have you adjusted the pilot screw at all for lean/rich conditions?
Postby neomuzzi » Mon May 07, 2018 9:16 pm
Pilot screw out too far.
neomuzzi
Postby Guesi » Thu May 10, 2018 1:00 am
Hello
The problem might be additional air intake..
Try to spray all critical areas with brake cleaner spray, which is high inflammable.
If the idle goes up or down, then you found the fault...
Guesi Motorradteile
MZ spare parts
Postby AlanJ » Thu May 10, 2018 3:35 am
Hi Dan,
I had forgotten about that one Guesi, good one. What about the filter Dan? If it's not good, with a fist full of throttle, ok, but as you close the throttle struggling for air. Just a thought.
Alan.
AlanJ
