Fork/suspension oil for ETZ 250
Postby arny » Sat Jun 02, 2018 5:24 pm
I'm interested what oil should I put in my forks and rear suspension units / dampers / shocks?
Factory calls for 8-11 cSt @50°C shock absorber oil, which corresponds to 2.5-5W fork oil (depending on the manufacturer). Haynes recommends 10W fork oil, which should have several time the cSt value at the similar temperature (about 30 cSt). Others (like here: http://www.sweller.co.uk/mz/workshop/wrk_shock.html) recommend ATF, which should have viscosity similar to the 7.5-10w fork oil.
So the main question is, should I put some light oil (apparently about 2.5w), per the factory recommendation, or should I go for those other recommendations and put heavier oil like 10w... in which case I could really use ATF because it has all the required properties (anti-foaming, friction modification, temperature stability etc.) and it's easiliy obtainable and very affordable...?
Arny
arny
Re: Fork/suspension oil for ETZ 250
Postby DAVID THOMPSON » Sat Jun 02, 2018 5:33 pm
over the years i have found 10 w to be a bit stiff 5w is closer to what i like in a ride
the roads here where i live have lots of pot holes
some so big that it is surprising no one has gone missing in one
Postby Puffs » Sun Jun 03, 2018 3:10 am
I see Dave. Hence 'if it's PAVED!'.
Arny, any of the recommendations will work, the key question is: how much damping do you want? That's quite subjective. And it depends on your riding style, and where/how you use the bike, and what you expect of it. Of course, how much damping you get from a particular viscosity also depends on the condition of the plastic piston rings, + other wear.
Suggest you start on one side of the range. If you're looking for a more comfortable & plush ride, start on the thin side, if you're looking for a more sporty ride, start thick. Then adapt viscosity if you find the damping too weak, or too stiff. You can also influence the forks' character by changing the oil level (more oil --> less air volume --> quicker rise in air pressure --> shorter stroke on same impact) & spring preload (spacers on top of spring). Keep left/right same.
Postby arny » Mon Jun 04, 2018 11:03 am
Well, since I'm quite heavy and I'll be mostly riding on... heh, paved roads - not perfect mind you, but acceptable quality - so I guess I might start on the thicker oil side. I'm not a plush ride freak anyway and I can stand up if needed - if 100 years people managed to ride fixed frame bikes on bad macadam, who am I to complain now... :lol:
But the question is - what exactly oil viscosities are "plush" and which the "hard" side?
The original factory spec calls for viscosity similar to 2.5w fork oil. OTOH, many people use 10w (or ATF which should be similar). Is it very soft with factory recommendation? Is it too hard with 10w... or more...? :?
Arny
arny
Postby Puffs » Tue Jun 05, 2018 4:03 am
Well, try 275cc of SAE10 then.
Postby arny » Wed Jun 06, 2018 2:29 pm
Thanks all, I'll play with the viscosities and try to find the best values... :wink:
Arny
arny
Postby parrbd » Thu Jun 07, 2018 2:19 am
I have always run ATF in my ETZ forks. It still seems pretty plush, then again I used to run SAE90 gear oil in my BSA B40 forks.
parrbd
Postby Puffs » Thu Jun 07, 2018 6:39 am
My ATF (Q8 Auto 15) has a viscosity not dissimilar to SAE10, yet seems a bit thinner. SAE10 is what Haynes recommend for both the ETZ forks and the shocks.
Postby arny » Wed Jun 13, 2018 1:03 pm
Ok, so I've decided to try ATF too. It has all the good properties forks should need, so it's just the matter of viscosity. It's also cheap. :-D If I find it too thick, I'll try a thinner grade fork oil (say, 5w).
Arny
arny
Postby Kruh » Fri Mar 06, 2020 12:56 pm
Puffs wrote:My ATF (Q8 Auto 15) has a viscosity not dissimilar to SAE10, yet seems a bit thinner. SAE10 is what Haynes recommend for both the ETZ forks and the shocks.
Can you even dissassemble the rear shocks and change the oil?
If yes, how?
Kruh
Postby Puffs » Mon Mar 09, 2020 6:28 am
The original ones you can, unscrew the threaded ring below the bump rubber:
and you can pull the whole lot out. See also pg 90 of Haynes.
Postby Kruh » Mon Mar 09, 2020 7:21 am
Ah, I see
Thank you
Kruh
