droy wrote:Regarding question number 3 and 4
You need a complete Tour rear subframe, seat rear bodywork, tail light and muffler to convert a Sport to a Tour.
I've done it. The fuel tank is the same and you can reuse the oil tank on the Tour.
DAVID THOMPSON wrote:i find the seat on a bmw /2 model 1955 to 1969 to be ok but handlebars where i do not lean on them
just relaxed and seated and no ape hangers you hands should be lower than your heart
my 2002 rt125 fit is excellent and very relaxed.. it is stock
the bars on the r90s i rode for years were set back about 20 mm
to remove the pressure of the lean forward that i did not like on that setup
the bars on the traveller have been raised and moved back but are too wide
but i do not ride it long range because it uses to much gas
rt125 at 55 gets me there because i do not have to stop
as often for gas max speed limit is 60mph any way
traveller makes a lot of bike shows here local
Dave
