New to me MZ 1000s
New to me MZ 1000s
Postby SilverBullet2019 » Sat Apr 27, 2019 8:21 am
Hey everyone,
Just became the proud owner of a 2005 silver 1000s with just over 10K miles. Wanted to see how the reliability has been for these bikes and any info for items to look out for would be very much appreciated! Also, the bike runs great and have added a joyful 50 miles on it already. Also, does anyone know of a high mileage MZ 1000s?
Used to own a 06 Harley Street Rod with the Porsche engine which I meticulously took care of, so no stranger to working with german engineering.
Again, thanks in advance for any feedback you are able to provide.
Thanks!
SilverBullet2019
Re: New to me MZ 1000s
Postby Joe Cool » Sat Apr 27, 2019 2:24 pm
Congrats on the purchase of a great bike. Neither of mine have high mileage, but last year one of my coils went bad while out riding.
Other than that I've had no problems. Where might you be located ?
Joe Cool
Postby SilverBullet2019 » Sun Apr 28, 2019 9:58 am
Atlant, GA.
Some more follow up questions...
What oil brand would you guys recommend? Tires?
SilverBullet2019
Postby Joe Cool » Mon Apr 29, 2019 5:08 am
Any quality full synthetic oil in SAE 10W-40 API SG or 10W-50 . 3.7L
I currently running Avon storm 3's which I like very much.
Joe Cool
Postby boilermaker » Mon Jun 03, 2019 6:14 am
The only weak point on these machines are the plug coils but there are a few standard commercial replacements for them. A German Magazine ran a long term test on these engines a couple of years back and found no measurable wear at about 50,000 miles.
George Waite.
boilermaker
Postby MJ310 » Fri Jun 07, 2019 9:47 am
Congrats on your purchase SilverBullet2019, I've got an SF with only about 22k miles on it but have had no real problems apart from gear lever return spring failure and plug coils, I now make my own so problem solved.
MJ310
Postby SilverBullet2019 » Sat Jun 08, 2019 6:40 pm
Thanks to all for your comments thus far!
I'm really liking the bike a lot and the more I ride it the more I like it. So far, it has fresh fluids, air and oil filter, brakes, battery, spark plugs and about to put a new set of Michelin shoes. However, I do wish they made a riser for the handlebar and stiffer mirror stems, it would make this S1000 absolutely perfect!
SilverBullet2019
Postby Thorsten-aus-SO » Wed Jun 12, 2019 1:11 pm
boilermaker wrote:The only weak point on these machines are the plug coils
No.
There is one point you should realy check. The screw which is fixing the tensioning rail for the cam chain. Here the link to the german board http://mz1000.motomonster.de/viewtopic.php?f=8&t=27.
There had been a few engine blow-up in the past.
Regards
Thorsten-aus-SO
Postby MJ310 » Wed Jun 12, 2019 5:20 pm
Thanks Thorsten, there is a lot of stuff to go through on a translator so could you give us the important facts about this problem?
MJ310
Postby Thorsten-aus-SO » Thu Jun 13, 2019 3:48 pm
The pictures are most interesting.
MZ has build less bikes than planned. So these self-locking screws (is this the word?) in stock are becoming old. That's why they are not as solid as they should be.
It is easy to check and to fix it with loctite.
Thorsten-aus-SO
Postby Joe Cool » Mon Jun 24, 2019 4:37 pm
Thanks much Thorsten-aus-SO for the info. This is the first I've heard of this. Correct me if I'm wrong, my under standing is to remove bolt and clean and install with lock tight ? right ?
Thanks much
Joe Cool
Postby Puffs » Wed Jun 26, 2019 4:04 am
Loctite Threadlocker.
Fyi, Loctite is a brand of adhesives, sealants and surface treatments. See also http://henkeladhesivesna.com/blog/the-d ... adlockers/ for some notes on use.
Of course there are also other thread locking compounds that work fine.
Postby Thorsten-aus-SO » Tue Jul 16, 2019 9:53 am
Joe Cool wrote:Thanks much Thorsten-aus-SO for the info. This is the first I've heard of this. Correct me if I'm wrong, my under standing is to remove bolt and clean and install with lock tight ? right ?
Thanks much
Yes. That´s it.
Thorsten-aus-SO
Return to 1000S
