Thanks for that link! Once again, I learn something from these discussions.
- P37.JPG (29.61 KiB) Viewed 18804 times
But what I don't find there, is that if you increase the squish size, you increase the risk of detonation.
If there is sufficient adiabatic compression of the mixture, its temperature can increase to levels above the self-ignition temperature (Mr. Jennings calls that 'compression heating'), and detonate, i.e. self ignite, before the spark in the plug causes it to. The squish band can help reduce this problem by locally enhancing contact with the (relatively) cool piston & head. More importantly, it focusses the mixture in an area close around the plug, as close as possible to a sphere, which makes the combustion more effective. Also, the gas flows as indicated by the arrows, further help adiabatic compression of the mixture in that central area, again aiding combustion.
Mr. Jennings explains, in the pages preceding P37, the background to the squish band: poor fuels from about 100 years ago, in side valve engines suffering from detonation. But detonation is not much of a risk in my case: while all the design specs for this engine are based on DDR fuels with rather modest quality (to quote the original ETZ250 manual, section 2.1. Kraftstoff: "Entsprechend der konstruktiven Auslegung des Motors ist ein Vergaserkraftstoff mit einer Oktanzahl ROZ von mindestens 88 zu verwenden (in der DDR Kurzbezeichnung "VK 88"). Außerhalb der DDR wird ein Kraftstoff mit ähnlicher Oktanzahl empfohlen.", the worst I can buy is RON95. More on octane rating & detonation in
https://en.wikipedia.org/wiki/Octane_rating . Anyway, the engine runs fine & if you don't have detonation, you will not increase the risk of detonation by adding more gaskets & thus lowering the adiabatic compression. For more, see 'Adiabatic heating' in
https://en.wikipedia.org/wiki/Adiabatic_process .
But rather than compression ratio's, the most important thing is, and Mr. Jennings says that too somewhere, the actual P & T of the mixture. In my numbers/spreadsheet I used the quoted compression ratio as an indication of how sound it all is, and conclude that 'compression ratio-wise I'm pretty much on spec', but of course the mixture knows nothing about any compression ratio - if P & T get too high, it just ignites/detonates. And if P & T are too low, combustion, as caused by the spark, is slow & inefficient. But I don't know the P & T in my bike, and particularly in a 2T they are very much dependent on the porting & port timing (all standard in mine). So it's a lot easier to compare in terms of compression ratio...
