ES150/1 twistgrip problem
Postby richardh » Sun Dec 15, 2019 4:11 pm
hi all,
new to your forum as just bought an ES150/1 1971
I seem to have a twistgrip problem whereby the rotation of the twistgrip does not operate the throttle cable.
I can see the spiral inside the twistgrip and I have the little block that hooks onto the cable - am I missing something please??
by the way - I used to have ES250/2 reg XBH 702J red and black and TS150 SMG77M are they still around I wonder????
thanks for help
richardh
Re: ES150/1 twistgrip problem
Postby DAVID THOMPSON » Sun Dec 15, 2019 7:18 pm
may have came loose in the carb or pulled the cable in toooooooo
Postby richardh » Mon Dec 16, 2019 1:17 am
The twistgrip parts are off the hanflebar completely, if i use pliers on the cable i can operate the carb fine .
Cable and carb are fine
There is something broken or missing on the twistgrip end or something not engaged correctly
richardh
