TS 250 horn and switch
Postby motorclocks » Sat Nov 07, 2020 4:38 pm
I got my relay problem straighten out thanks to you guys but im stumped on my horn, not sure of wiring since i cant follow diagram. the white wire in my button they have grounded is that right? purple I assume is hot. Horn harness (Black & white) not sure how they should be hooked up in the head light housing
motorclocks
Re: TS 250 horn and switch
Postby dave47 » Sun Nov 08, 2020 7:52 am
The standard horn switch has only one wire and that obviously isn't it.
Your 2 wire horn switch (if thats what it is) could be connected 2 different ways. Is the white wire already on the earth terminal? If so the purple wire must go to the horn, i guess. And the other horn wire (black) would go to the ignition switch. But your electrics have obviously been modified so this is only my best guess. Other circuits are possible.
dave47
