stripped out allen head bolt in oil filter cover
Postby Little General » Thu Dec 17, 2020 5:08 pm
The top right bolt in the oil filter cover is stripped out on the bike I just bought. Its behind the exhaust pipes and the don't look like would come off very easy. The only way I see is to drill it out and try some vise grips to remove it . Any ideas?
Little General
Re: stripped out allen head bolt in oil filter cover
Postby Little General » Thu Dec 17, 2020 5:49 pm
Well, you tube to the rescue. I took a star bit and hammered it into the allan head and it came out.
Little General
Postby DAVID THOMPSON » Thu Dec 17, 2020 6:38 pm
some times hard taping helps
then vice grips on the head and twist..
helps with this kind of problem
