New to me 1995. MZ Country 500
Re: New to me 1995. MZ Country 500
Postby DAVID THOMPSON » Sun Dec 27, 2020 3:56 pm
removing the cover is OK
it will not save on the mess
this bikes oil change seems the be a mess
its the biggest mess of any bike i have ever owned
Dave
Postby Puffs » Mon Dec 28, 2020 4:46 am
Then you'll be doing similar as I with my SP. Place a suitable bowl...
Rotax is Austrian so I'd guess that cover is made there too. But indeed maybe aftermarket - or old stock? Maybe Can-Am also used Rotax?
Quick look says yes, they still do.
Postby breakwellmz » Mon Dec 28, 2020 6:16 am
What engine is that? Looks like half of a water-cooled twin in the image i can see.
Postby Puffs » Tue Dec 29, 2020 6:50 am
Right-mouse click --> view image; in that pic it's both the 900 triple & 600 twin from their Ryker https://can-am.brp.com/on-road/us/en/models/ryker.html
In their Spyder they put a 115HP 1330cc Rotax. Also in 2021.
More: https://www.rotax.com/en/products/rotax ... rains.html
Postby Little General » Tue Dec 29, 2020 12:26 pm
Well that sure ain’t the little 500 single in my bike. Yes Can Am uses the Rotax engines and most of the parts are the same except the bing carburetor and exhaust systems.
Little General
Postby DAVID THOMPSON » Tue Dec 29, 2020 1:43 pm
give me the 600 ace with cvt and a wood racing flat track frame
and i will build a weapon that will scare people
atkusa 605 esds mid 1990's comes to mind but a bit on the tall side for short people
and if you find a good used one you need a DEEP pocket book
Postby breakwellmz » Tue Dec 29, 2020 2:20 pm
CVT is interesting -
They do look good, not come across a road legal one before.
Postby Puffs » Wed Dec 30, 2020 6:49 am
I don't know the details of their CVT, but it is likely to cost power. I don't mind shifting.
That's a nice looking flat track bike. It isn't, but it reminds me of the CCMs from a while back; didn't they also use that Rotax engine?
The ATK David mentioned:
Gorgeous bike IMO. Details from https://www.motorcyclespecs.co.za/model ... 5%2096.htm
Postby breakwellmz » Wed Dec 30, 2020 7:44 am
Probably the largest user was Harley D and Armstrong for their military bikes.
Postby Little General » Fri Jan 01, 2021 4:49 pm
I have new tires coming Monday and I understand there is a certain way to remove the rear wheel. I get that I remove the left hand axle bolt which is separate from the right side that holds the sprocket side. Exactly what happens next. Remove the spacer and does the brake hub come off with the wheel ? I understand I think the wheel comes off and the drive sprocket stays. Any help or pics would be great. Otherwise I will play it by ear.
Little General
Postby DAVID THOMPSON » Fri Jan 01, 2021 7:13 pm
hold nut on right side and remove axle on left
it may be o there very tight
remove left spacer brake rod and brake hub then wheel
leaving hub on right and chain in place
the axle is a 2 piece with part of it staying mounted with chain and chain cover
axle is removed out left side
Postby Little General » Fri Jan 01, 2021 8:25 pm
Thanks Dave. Since there are a few people that have asked and no pics , I will try to document the process in photos. It seems Bridgestone has a new tire , the Battleax 41 , that is the correct size and hopefully it won’t rub the rubber chain enclosure. It the outer lugs touch the chain protection, I will just trim them down a little with a side grinder. If I get that far , I am not removing the tire. Lol.
Little General
Postby Puffs » Sat Jan 02, 2021 5:53 am
Postby DAVID THOMPSON » Sat Jan 02, 2021 10:06 am
i have reached the point if i take any thing apart it has to be in small pieces
or i have my feet stuck on the ceiling and my face buried in the FLOOR
my get up and go is on strike
:smt006 now 75 and on the down hill slide
Postby Little General » Sat Jan 02, 2021 2:14 pm
Thanks Dave and Puff. I think I understand it now. Seems fairly straightforward.
Little General
Return to 500 cc
