OK, here are some links for you:
Spare parts list:
http://www.miraculis.de/aw/download/mz/ts250e.zipWorkshop manual:
http://www.miraculis.de/aw/download/mz/ts250r.zipWorkshop manual:
ftp://blurredmanswebsite.ddns.net/Vehic ... Manual.pdfUser manual:
http://www.miraculis.de/aw/download/mz/ts1525b.zipThe ones from miraculis are in German, but there are a few browsers which include automatic translation of an HTML text.
To translate a HTML browsed in any browser, enter the text "https://translate.google.com/website?sl=de&tl=en&u=<desired URL>" into your browser's address field. In that,
sl = source language
tl = target language
u = URL
Obviously adapt as required.
Note: these links are for a TS250, if yours is a TS250/1 you need other documents.
On the technical: this is a two-stroke engine. Seals #14 isolate the crankcase from the gearbox and the oil from that. There is normally no oil in the crankcase, lubrication of the conrod bearings and the cylinder/piston is by oil in the premix, while in this model the main bearings are lubricated by gearbox oil. See this pic:
- 2G.JPG (31.64 KiB) Viewed 2058 times
If the engine leaks oil, it is not due to the crankshaft seals #14. Possibly the drain plug is leaking, or maybe it comes from the gearshift lever, output shaft seal, or something with that clutch thingy. Look carefully where it comes from (which is probably not exactly above the puddle of oil on the floor).
I'd be surprised if seals start to leak just by time, normally wear is required, but it is possible. It's also possible that during the initial running much accelerated wear was caused by some corrosion on the shaft that should be sealed. Nevertheless, the oil leak is probably not the cause of your running issues.
If you feel no (or a reduced) compression on the kickstart lever, I recommend you take the barrel off, and inspect bore/piston/rings. That is quite easy to do, and for instance insufficient lubrication (did you premix properly?) may also cause your problem.
On this model I don't think you can replace the seals #14 without taking the engine apart, the main bearings are in front of them.
