Lucky lucky lad!!
Lucky lucky lad!!
Postby JawasandMZs » Sun Aug 14, 2022 6:02 pm
I'm a lucky lucky lad. I was out earlier on my Jawa and the throttle cable broke, at the nipple end in the throttle tube. I struggled home by turning in the tickover screw on the carb.
Once safely home I realised that the throttle cable in fact operates the oil pump too. So if you're relying on adjusting the tick over screw to go faster you're not getting any oil to the engine, resulting in seizure.
Thank I thought to myself oh my God thank GOD I run this bike on premix!!!
What a life saver!
Edit: in conclusion I'd strongly recommend replacing the throttle cable every 3 years as a precaution. It's what I'll be doing from now on.
EDIT 2. just installed the new cable, fiddly one hour job, one of them annoying jobs where things go ping if let go. Blurred man honestly thinks it's a feasible job at roadside. Blimey,for you maybe!
I'd be better off with cable ties and mole grips!
JawasandMZs
Re: Lucky lucky lad!!
Postby DAVID THOMPSON » Sun Aug 14, 2022 8:47 pm
the auto lube is nice but on my Yamaha ym1 305 1966 i added enough premix to make it smoke a bit
traded it on my first bmw wish i had kept it for the collection mine was red
it ran real good on the same spark plugs as my r50s bmw
https://en.wikipedia.org/wiki/Yamaha_YM1
owned some nice stuff over the years but did not kill the billfold like some of the fellows
and not into trail bikes except turned a bunch of them into daily drivers for other people
who like me do not drive where the trees jump out in front of them
Postby Blurredman » Mon Aug 15, 2022 2:20 am
I have always been of the belief that one should carry spare cables- the important ones, Clutch, throttle. :-D
Postby parrbd » Mon Aug 15, 2022 3:11 am
Back in 1973, I rode my BSA B40 over some 50 miles of dirt road pulling on the knotted end of the cable and steering with one hand.
parrbd
Postby Puffs » Mon Aug 15, 2022 3:53 am
Postby Gerryman Ts125 » Mon Aug 15, 2022 10:36 am
My Ar 125 was always shredding the lever end of the throttle cable, so I listened to my mate. He always carried a cable tie and a small speaker cable splicer. You stick the cable splicer on the dead end of throttle wire and clip it/ hit it with a brick ( plenty of them lying at the side of the road), then cable tie it to the throttle lever. Seldom fails, even if your throttle is `fly by wire ` :smt005
Gerryman Ts125
