rear wheel
rear wheel
Postby sean18 » Fri Oct 21, 2005 1:58 am
hello all a silly question :oops: how do you remove the back wheel of a sm 125. i tryed for about 1 hour and its still on. ive removed the axel nut on one side but the axel will not come out ive tapped it no still there :evil: i hit it a bit harder its still there :twisted: i hit it very hard and its still there :twisted: :twisted: .is there any thing iam missing
sean
sean18
Postby jbthumper » Fri Oct 21, 2005 3:35 am
hi sean, was the wheel straight(i mean align) when you hit the axle...?
lift the wheel a bit while you're hitting it(the axle..haha)...
i don't think you did anything wrong....
last time when i took mine out, i just gave the axle a few taps and the thing moved... :?
maybe you can try spraying some wd40 on the axle(or anything that's touching it)
hope this helps...
:smt033
jbthumper
Postby sean18 » Fri Oct 21, 2005 2:21 pm
all done i just used a bigger hammer :-D ...the axel was seazed but it out now thanks
sean
sean18
Postby jbthumper » Fri Oct 21, 2005 4:27 pm
no problem... intimidating the bike with a bigger hammer usually helps in most cases :-D
:smt033
jbthumper
Postby phlat65 » Fri Oct 21, 2005 10:53 pm
always grease the entire axle upon re-assembly, prevents seizing again!
Return to 125 cc
