MZ Baghira / KTM 640 Adventure Bodywork
Re: MZ Baghira / KTM 640 Adventure Bodywork
Postby breakwellmz » Fri Nov 04, 2022 7:19 am
So has it got twin CV carbs?
Postby 7inarow+ » Sun Dec 11, 2022 7:01 am
Hi, it had a 42mm cheap eBay single carb with the other inlet just blanked off. It run but was gutless so I thought I would take the time and put the original one back on.
It runs well with good top end. I must admit I expected a little more snap on take off so might investigate further, or it’s because I’m so used to road bikes performance.
I’ve fitted a plug in choke which work well, down side because of the 30 ltr tank is hard to operate. Would like to fit a cable operated one but having trouble finding one. Cable easy, actual choke no.
7inarow+
Postby breakwellmz » Wed Dec 14, 2022 10:01 am
I thought that it had too much carb with the originals which made it to revvy for a 660 single, hence me putting a 40mm CVK on mine (love it BTW!) -
I had a bicycle gear lever mounted on the bars as a choke lever at on point, i probably have it somewhere.
MZ CARB COPPER.JPG (55.41 KiB) Viewed 10229 times
Previous
Users browsing this forum: No registered users and 47 guests
