Chain and lube
Chain and lube
Postby JSC_SLP » Wed Jan 04, 2006 12:33 pm
OK so I've decided to get PJ1 lube and kerosene to take care of my gunked up chain.
Question: How do I know if I have an "O-ring. X-ring, or standard chain?" It depends on what type of lube I would need to buy. PJ1 Blue (o-ring and x-ring) or Black (standard/ non o-ring) can.
If possible can you post a pic of a chain?
2001 Skorpion Tour
JSC_SLP
Postby keithcross » Wed Jan 04, 2006 1:30 pm
If you buy a chain lube suitable for o ring chains it will work fine for a standard chain.
Postby whysub01 » Wed Jan 04, 2006 4:33 pm
Fit a Scotoiler, and never worry about chain lube again!!
whysub01
Postby keithcross » Wed Jan 04, 2006 5:58 pm
A Scottoiler is definatly the way forward, been using one for 2½ years on my Baggi
Re: Chain and lube
Postby cat » Thu Jan 05, 2006 8:07 am
JSC_SLP wrote:OK so I've decided to get PJ1 lube and kerosene to take care of my gunked up chain.
Baghira comes with an o-ring chain. (afaik.)
If you're used to ordinary / non-o-ring chains, an o-ring chain will look like there's a slight space between the outer plates and the inner bushings. Look at yours and then look at a bicycle chain if you haven't got a 'normal' bike chain around to look at.
cat
Postby JSC_SLP » Fri Jan 06, 2006 9:01 am
Great, thanks I think I'm all set.
2001 Skorpion Tour
JSC_SLP
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
