Raptor carbs (again)
Postby irishnutjars » Sun Apr 09, 2006 7:46 am
Any one got any more information on fitting these to a baghira? Seem to be a reasonable price to pick up a pair.
I remember reading someone did it but no more info other than that it worked & very well! I presume I would need rubber boots also from raptor both from airbox and to head? Is it a major job? Would I need to rejet them? Am I crazy? :roll:
Thanks!
irishnutjars
Postby CM » Mon Apr 10, 2006 3:16 pm
The raptor carbs fit!
You need a different connection from airbox to carb, because the raptor carb is shorter than the original teikei.
If you can understand german oder have a good dictionary, look at http://www.mz-baghira.de (search for "Raptor Vergaser" or "Mikuni BST 33")
One or two guys are driving this carb.
CM
Postby irishnutjars » Mon Apr 10, 2006 4:15 pm
Thanks CM,
Tried the site- even registered but its making my head ache (:oops:) translating with my exceptionally limited German & babel fish online translation!
Doesnt sound like a big job to make an extension from carb to the standard connecter, but isnt one of our standard carbs diameter smaller?
Just like to know if its worth the effort & expense for the gain. Im sure I'll get them on somehow! I have the carb & header kit from tunebike.de and would like to be able to afford the stage one kit but these look like like a more realistic option for me!
irishnutjars
Postby keithcross » Mon Apr 10, 2006 4:43 pm
Thought about fitting the complete head and carb assembly to my MZ and still might if I can get the parts for the right money. This should mean that the engine limiter could be saflly changed to one that allows the engine to rev highr as I understand the limiting factor for this is the valve gear.
Could be wrong though
Postby CM » Mon Apr 10, 2006 5:09 pm
The guy who drives with the BST means that the Baghi is a lot more spontaneous.
If you need the gauges of the different manifolds I can ask him also for the size of the main jet and so on.....
I would try it with the BST 33......but I still have my nice Mikuni flat slide :twisted:
Here is my little help for some german - english and english - german questions ;)
http://dict.tu-chemnitz.de/dings.cgi?la ... dlink=self
Or ask in the Baghi Forum, they will help you as far as possible!
CM
Raptor Carbs Again
Postby basser23 » Tue Apr 11, 2006 12:05 pm
As I understand it, the Raptor manifold fits perfectly. Also, you'd
probably need to fabricate a battery box if you use pod filters.
I am curious about the throttle linkage set up...any thoughts?
Chip
96 Skorpion
basser23
Postby CM » Tue Apr 11, 2006 1:39 pm
For the Baghi, you need a distance piece to the airbox because the carb is shorter than the original Teikei. Everything else fit.
CM
Postby tuny » Tue Apr 11, 2006 1:46 pm
so what do you get with the raptor carbs? more torque? or power? why change?
tuny
Postby CM » Tue Apr 11, 2006 1:50 pm
The MZ is more spontaneous on the gas and gets more power.
I have a Mikuni flat slide, not the raptor carb.
If you need more precise infos, ask at http://www.mz-baghira.de ....they understand you if you write on english :P :-)
CM
Postby basser23 » Tue Apr 11, 2006 2:39 pm
CM,
You are running a pair of TM34's right?,not just a single...
So the linkage fits too....hmm
Chip
basser23
Postby CM » Tue Apr 11, 2006 2:43 pm
The Mikuni TM34 B65 is a double carb, two 34mm carbs....
If you drive one carb you need a TM42 or something similar...maybe 41....I don´t know....
CM
Postby basser23 » Tue Apr 11, 2006 3:08 pm
The tm34b65 is hard to locate here in the states, Most people who change the carbs are running Keihin FCR's 35mm(usually)and they are pricey.
I may just try the Raptor carbs .
Chip
basser23
Postby DEmark » Tue Apr 11, 2006 3:10 pm
I got a question, does the Mikuni TM34 B65 have an accellerator pump? Did it fit up pretty well?
How about the Rapter carbs, do they have an accellerator pump?
DEmark
Postby keithcross » Tue Apr 11, 2006 3:19 pm
Looked at this parts fishe
http://www.yamaha-motor.com/outdoor/parts/home.aspx
There doesent appear to be a acc pump fitled.
Postby CM » Tue Apr 11, 2006 4:20 pm
Jep, TM34 has a accelerator pump. If you hold the carb in you hands and turn the gas, you can see a little fuel rey coming out of the jets in each carb.
When the Baghi is out and I turn on the gas for some times, I have problems to start her, but after a few tryings she runs again ;) Sometimes the spark breaks in fact of too much fuel....but if you got the clue, it´s no problem....if not.....hm.... :-D
The Keihin is good too, I guess but he´s maybe a little bit too (1mm bigger than TM34) big for a normal engine. With a normal engine and the TM34B65 (it also exist a TM34B70 and bigger) is very spontaneous, maybe to spontaneous because some guys don´t like the carb on a standart motor....When he´s tuned, the carb can show his ful potencial ;)
The Raptor carb is an impulse carb (in german "Gleichdruckvergaser") and has no accelerate pump.
CM
