fork oil grief
fork oil grief
Postby reb » Mon Jun 19, 2006 12:40 pm
hi to all
i've just put new seals in the forks on my skorpion sport special
the book says 350ml of fluid per leg but that seems far too much !
are there different forks with different volumes or something ?
or does anyone have a measurement from the tops of the forks to the oil level ?
the bike is a 96 model sport
thanks in advance of expert advice
reb
reb
Postby Chris Hunsicker » Mon Jun 19, 2006 2:48 pm
No grief necessary!
300 ml Tour
350 ml Sport
Some people indeed go with a measurment: from the oil level to the top of the tube with the fork compressed (without the spring!) is 160 mm.
I always go with 350 ml and leave it at that. You may need to compress your fork a few times before you add all the oil to get the air out, but honestly I've never had to do that either.
10 w is stock, I like 12.5 and have used 15 w as well.
Chris Hunsicker
Postby reb » Tue Jun 20, 2006 5:23 am
i think the thicker oil is best as there is a bit more weight over the front end than standard
thanks for the info !
reb
reb
Postby keithcross » Tue Jun 20, 2006 6:30 am
Wow, what motor is that. Look like a Yamaha 750/850/900 twin.
Postby reb » Tue Jun 20, 2006 6:39 am
850
not the best fit in the world - still needs a nice tank making etc
but it has solved the performance shortage of the single cylinder engine
reb
reb
