Gasket sealent
Gasket sealent
Postby saxonetz » Fri Jul 25, 2008 2:30 am
Hello all, quick one, i'm putting the barrel and head back onto the crankcase of my ETZ125, before i sit the barrel down on the crankcase gasket should i smear some sealent along both sides of the gasket? cheers Vin
saxonetz
Re: Gasket sealent
Postby TS2Fifty » Fri Jul 25, 2008 5:18 am
I usually put a very thin smear of orange sealant just round any transfer ports or oil/coolant passages when putting a barrel on, although the new gasket (should always use a new one) ought to be perfectly OK as it is. Your choice at the end of the day, but I'd say it can't do any harm as long as you don't lump it on. :-)
TS2Fifty
Re: Gasket sealent
Postby manumensa » Fri Jul 25, 2008 10:56 am
Hello!
All joint-papers have to soak in oil or grease. If the surfaces (crankcase and barrel) are OK no problem.
For joint the half-crankcases I use Hylomar, this sealant is good and clean it after for new re-build is very easy.
Saludos, Manuel.
manumensa
Re: Gasket sealent
Postby TS2Fifty » Mon Jul 28, 2008 9:51 am
manumensa wrote:Hello!
Once again, I learn a lesson the easy way! :mrgreen:
manumensa wrote:For joint the half-crankcases I use Hylomar, this sealant is good and clean it after for new re-build is very easy.
Saludos, Manuel.
The blue 'semi-hardening' type? That stuff is magic. ;-)
TS2Fifty
Users browsing this forum: Bing [Bot] and 3 guests
